Brake fluid change -how to:
On 2000 vette will be changing shocks to adjustable QA1's; changing rotors and pads for road track days; and:
1. installing steel brake lines
2. changing the fluid to Motul 6
3. have Motives fluid changing suction canister to get fluid out of master -
what is my sequence?
suck out the main 1st, open all the lines next or one at a time and bleed the lines -do not want air in lines- then fill in new fluid and reconnect the lines
Thanks for your help!!
LS1TECH Sponsor
You cna suck all of the old fluid out then drain the lines as well. Put new fluid in and let it gravity bleed for a bit. Then use the vacume pump to bleed the rest.
