UMI Subframe Connectors
Old Jan 20, 2007 | 10:43 AM
Kalgorn's Avatar
Default UMI Subframe Connectors
So I Just got my set of boxed-style weld-in 2-point SFCs welded in on Tuesday morning. I noticed immediately when I left the shop that if I go over a relatively large bump (or railroad tracks) and sometimes on a shift, the driver's side rear chatters a bit. I talked to the shop and he said he talked to another guy that has SLP connectors and his does the same thing and he can't think of a way around it.
Any of you experience the same thing? Is there anything I can do about it? He said to come back in a month to check on the welds so if you guys can think of something, maybe I can bring it up.
Old Jan 20, 2007 | 01:04 PM
ZodiacZ28's Avatar
Wish i knew too. I had edelbrock sfc welded in. mine does the same thing.
Old Jan 20, 2007 | 01:52 PM
Kalgorn's Avatar
Is it just driver's side for you too? I can't figure out why it's just one side...
Old Jan 20, 2007 | 01:54 PM
Ralls's Avatar
I haven't experienced this, but I'm curious.. what shop did it for you?
Old Jan 20, 2007 | 03:27 PM
UMI Performance's Avatar
Hello,
Its the rear control arm bolts not being tight enough. Our SFC sandwiches the rear control arm mount, when they tighten the mount it will require more pressure to compress the bushing. Try tighting the drivers side bolt some more and the noise should go away. We have found even up to 90 ft lbs may be needed.
This is also in the installation instructions
Hope that helps,
Ryan
Old Jan 20, 2007 | 04:11 PM
slim0035's Avatar
I had the same problem untill I finally installed new LCA's and the noise/rattle stopped...apparently I got it tight enough.
Old Jan 20, 2007 | 06:11 PM
Kalgorn's Avatar
Sweet deal! Thanks, UMI. When I go stop in for them to check the welds, I'll tell them to tighten the bolt.
I had this done at Knopp's Performance two blocks from my house. I know a lot of the guys that work there and hang out there drive either F-Bodies or older muscle cars so I figured I'd give it a try. I would definately go there again if I need something done.
Old Jan 20, 2007 | 06:33 PM
mcamarols1's Avatar
Originally Posted by UMI Performance
Hello,
Hope that helps,
Ryan
the same thing happened to me, ^^^ this fixed it, i love umi!!!!
