Drag launch springs question
I was wondering, if the drag launch springs for the LT1 models will work in an LS1 model. I don't see why not but I thought I would ask to be certain.
I don't know the spring rate on the springs but the front are a turd to put on they are so tight.I had them on my car for about 6 months and they would transfer so hard at the track that i could'nt get traction.That was a good investment for the money.
Does anybody know whats wrong with my car,i put a set of drag and launch springs in my car and it lifted the rear alot, and its also hire on one side then the other in the rear.Is this normal,or are my shocks gone, or is the installation not right,if someone could help, id appreciate it.
It should raise the rear a bit. If the right side is higher check how much air is in the bag. Thats the only thing I've run into with them, however its been only on mustangs.
They will raise the rear about an inch. Make sure the rear springs are on the right sides, they have a RR and LR on them.
I run around 5lbs in the RR airbag on the street and experiment with different psi at the track.
