Which Shocks!~!~!~????
Old Jan 30, 2007 | 07:55 PM
DarkLoneWolf666's Avatar
Question Which Shocks!~!~!~????
Well im in the market for new shocks and im confuse to choose between
KYB Shock Absorber: Gas-a-Just or Bilstein . Whcih one??!!!
Old Jan 30, 2007 | 08:12 PM
Flawless02SS's Avatar
It really depends what you plan to do with the car. If you plan to just mainly drive the car on the street, any shock on your list will do. I went with the KYB Gas-A-Just. Just change them out around every 30k-40k and you should be good.
Old Jan 30, 2007 | 08:15 PM
btw i forgot to tell you guys i have Eibach Sportline Lowering Springs equip to this car. which lower like 1.8 inch if im right.
Old Jan 30, 2007 | 10:18 PM
Old Jan 30, 2007 | 10:32 PM
OldeSkool's Avatar
Well... aftermarket springs greatly reduce your shock choices. rather, you can expect to pay more for sufficiently valved dampers. High spring rates (as found in lowering springs) require well made dampers in order to control them for any reasonable amount of time (that is, if you want them to last more than a couple thousand miles).
In other words. Koni SA's are the "cheapest" shocks that will work for you (unless you want revalved bilsteins) They are relatively expensive compared to the mediocre shocks most people are familiar with, but there are actually lots of way more expensive shocks out there. Motons and Penskes that can cost thousands of dollars a set.
Old Jan 30, 2007 | 11:10 PM
well okay. . wheres a site taht i can buy Motons and Penskes??? i never heard of them. So you saying KYB Gas-A-Just wont work?? i was just goign to send it to Big O tires.
Old Jan 31, 2007 | 04:00 AM
looks like im jsut goign to go with KYB Gas-A-Just
Old Jan 31, 2007 | 05:07 AM
UKCamaroSS's Avatar
Hi,
I suppose you will end up with the KYB's, which in my opinion would be a bad choice. I have Koni SA's now and Strano springs.... a long time ago I had Eibach Sportlines and SLP Bilstein's.... best thing I did was to get rid of them... both.
Koni SA's can be bought from Stranoparts (Sam).... excellent customer service
Penske's can be bought from Unbalanced Engineering (Jason).... I've not dealt with him, but I hear really good things about their support also.
Moton's..... if youv'e got loads of money (in the region of $5K I think).
Regards,
UKCamaroSS
Old Jan 31, 2007 | 05:09 AM
Danger731's Avatar
Koni's for you
Old Jan 31, 2007 | 08:43 AM
chupr0kabra's Avatar
Please don't get GasAJust shocks. I have a set, and they're currently doing what they were apparently designed to do: sit on a shelf in my garage, to be used only if one of my Koni SA's dies and I absolutely NEED to drive my car somewhere. I ran them for a few thousand miles with Hotchkis springs and they weren't up to the task. I'm sure they'd be even worse with Sportlines.
-Mike
Old Jan 31, 2007 | 09:02 AM
coolformula's Avatar
blistein all the way, just keep the stock springs. Should be good to go.
Old Jan 31, 2007 | 09:35 AM
Zach@MTI's Avatar
Bilsteins are definitly the way to go. I have a few sets in stock that I'll make a good deal on. Let me know if I can help!!
Thanks,
Zach
Old Jan 31, 2007 | 03:36 PM
which set should i get on Koni? the Koni Adjustable Shocks (complete set)?? or the Front & Rear ones. There are 2 different sets for 2 different price. Sorry Zach, the bilsteins are not made for my springs and Coolformula. . . i got rid of my stock springs a long time ago. . LOLZ.
Old Feb 1, 2007 | 10:43 PM
OldeSkool's Avatar
You need 4th gen koni's up front, Single Adjustable is best for most people. You can use either 3rd or 4th gen rears (3rd gens are cheaper but must be taken off to adjust).
Should be about 500 for the front pair, 300 for the rear pair (4th gen) at least thats about what I paid
Old Feb 2, 2007 | 08:08 AM
z_speedfreak's Avatar
I would opt for some revalved bilsteins myself to match those springs.. and save a few hundred.
Old Mar 6, 2007 | 02:27 AM
DUDE!~!~! MY RIDE IS SMOOTHER NOW SINCE I INSTALL THE Koni's SA IN THE CAR. . well big o's did it along with m new set of tires. . Toyo T1R. . . so i just spend about 2k on the whole system. RIDES NICE NOW. . no more rough roads for me. . THANKS FOR HELPING ME OUT GUYS!~
Old Mar 8, 2007 | 05:05 AM
Danger731's Avatar
sweeet
Old Jun 3, 2007 | 08:47 PM
FireSilverLullaby's Avatar
so are the revalved blisteins adjustable in any way. And the konis you can adjust the stiffness/softness. and how many perches is their to adjust the ride height?
Old Jun 3, 2007 | 09:56 PM
No.
For Koni SA's, you can adjust the rebound. Koni Double Adjustables let you adjust both compression and rebound.
On the Koni SA's, the front shocks have two perch locations: stock and lowered. There are not multiple perches on the rears, since the springs don't mount that way. The Bilsteins have one perch.
-Mike
Old Jun 3, 2007 | 10:35 PM
alright thanks alot, this might make the decision to go with the blisteins a little easier.
