konis
Old Feb 1, 2007 | 07:30 PM
Disturbed Bird's Avatar
Default konis
will i see a big deference if i get konis double adj. over the mods i already have in my sig?
Old Feb 1, 2007 | 07:50 PM
subtlez28's Avatar
The DAs would likely be overkill. I would highly recomend the SAs (single adjustable). You will basically tune to suit ride and spring rate. Once you r happy there shouldn't be much adjustment anymore. Shock tuning is a complicated issue. Plus the SAs offer the lower perch, so you can lower the front w stock springs.
And you WILL notice a diff, both in handling and ride quality.
Old Feb 1, 2007 | 07:55 PM
all right thanks
Old Feb 2, 2007 | 10:39 AM
Sam Strano's Avatar
LS1TECH Sponsor
Your pockets will be lighter and you'll be more confused.... other than that they're great.
I have a set, and *I* don't run them since they are a much bigger pain in the *** then most anyone needs, including myself.
__________________
Old Feb 2, 2007 | 11:05 AM
Speed's Avatar
So for a daily driven car that will see at least one Solo II or track event a month, the single adjustables will work well? Ultimately will the double adjustables get you around the race track any faster?
Old Feb 2, 2007 | 11:06 AM
02SS#406's Avatar
If it did, Sam would be using them...
Old Feb 2, 2007 | 12:50 PM
Speed's Avatar
Kewl thanks
Old Feb 2, 2007 | 03:22 PM
thats what i needed to know thanks
