Should I do the hose mod (! Rear Isolator) with Intrax Springs??
I know to use 5/8 heater hose but I am wondering if I should do this when installing my LT1 Intrax Lowering springs on my 97z. Some seen to say that the Intrax rides higher in the back then they would like but idk
Not running LT's and I have a adj panhard rod
The heater hose mod will drop the rear about 3/4". The only way to know for sure is to try it, rear springs are pretty easy to swap out. More than likely however, there isn't 3/4" difference from front to back, so you would end up with the front being higher.
