NEED HELP!! (Non-Ls1 ABS Question)
Ok guys, I have a 1996 Pontiac bonneville. I am trying to replace the ABS wheel speed sensor hub assembly. I have the tire off, caliper off, rotor off, but now the sensor does not want to come out. It is extremely rusty, given that it is my winter car and everything. It is stuck to a brace.
I have used penetrating oil and it still won't budge.
Any opinions?
Any opinions?
the area where the caliper bolt's to is the best place to hit the hub with a hammer to jar it loose ...if you have an air hammer with a thin blade you can get in between the hub and the spindle to remove it that way also...good luck...
