(You Must Read) Fixed Rate or Variable Rate Springs
Kleeborp the Moderator™
Originally Posted by gollum
BULLSHIT! All 4 into 1 long tube headers WILL drag especially over speed bumps lowered or not lowered.
Anyway...fixed rate springs are easier to dampen than variable rate springs.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
i stopped my car on a speedbump at various different points and measured about 2" of clearance with my pacesetters - stock ride height
Good read. I was always interested in the performance difference between fixed rate and variable/progressive rate springs. It never crossed my mind that the shock would have to accomodate for the gradient of a progressive rate spring. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I just purchased some Strano springs a few days ago. I knew I made the right choice.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Originally Posted by MeentSS02
Where are you getting this information? The header collectors are NOT the lowest point in the system if you have decent headers (i.e. anything other than SLP headers).
Originally Posted by Redlinez
Just remembered, mine were Hypercos and I loved them.
I went with SLP Level II springs (Eibach) on the uppper perch of the Koni in the front and the stock 1LE springs with Koni in the rear. I think its the best set up for the convertible.
I don't race though. I also have 30lbs of mufflers under the rear bumper, 65 lbs. of Dynamat throughout the car, and another 45 pounds of custom sub enclosure and amp in the rear. And I always have a full tank of gas.
No matter what you do in the aftermarket world someone will not be happy. It is absolutely impossible to please every customer out there. If Sam was to make a 3/4" drop sping he may gain a few of you for business but loose the others who prefer the spring he offers now. If he was to produce both styles the price for a set would be quite a bit higher because they would be producing half as many of the size he currently carries. This means more design time, set-up time and production time would need to go into the other set. The production numbers of the springs would be lower and the price would go up. For Sam to put 3/4" springs on his shelf they may sell here and there but he may feel that is a lot of investment sitting there to sell one set a month. I am in manufacturing, I know how this works why he has choosen to do what he has.
As for headers and lowering springs. If you buy a good fitting set of headers (Kooks, Stainless Works are good examples) you will have no issues with clearance on a lowered vehicle.
Ryan
Ryan
In reality, the y-pipe will scrape long before the headers, especially if you have a catted y-pipe. Ask me how I know.
A recent thread about this:
https://ls1tech.com/forums/suspension-brakes/664548-progressive-rate-springs.html
Some of the information I said was wrong, but was corrected later in the thread. I feel it was a pretty intelligent discussion.
And your "I know more than everyone else and I'm always right" attitude sucks. A lot.
-Mike
#32
LS1TECH Sponsor
__________________
#33
I just purchased some Strano springs a few days ago. I knew I made the right choice.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Wrongforum](https://ls1tech.com/forums/images/smilies3/wrongforum.gif)
we're talking headers here!!!!
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#34
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Originally Posted by Sam Strano
You need to be carefult about absolute statements...
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
My friend, you have been
![Owned](https://ls1tech.com/forums/images/smilies2/owned.gif)
![Try Search](https://ls1tech.com/forums/images/smilies/trysearch.gif)
#35
You stock springs are linear, and my StainlessWorks headers don't drag. You need to be carefult about absolute statements...
#38
LS1TECH Sponsor
come on dude... let's get real. I'm not going to tell you anything of the sort, I'd be insane. I'll tell you that my headers use 2.5" collectors, which automatically gets me ground clearance (and I out torqued a set of 3" headers too). No two cars are the same. Maybe your motor mounts suck and the engine sits lower?
__________________
#39
I can see why a shorty headers would not drag and I have seen pictures of a new TRI-Y LONG tube header with twin 2.5" collectors that I know would clear most anything. But all current 4 into1 long tube headers will drag when lowered.
Are Performance Friction Carbon Metallic brake pads any good?
#40
I think it's time you turned in your LS1Tech username.
