need help... alignment problem
Old Mar 7, 2007 | 09:55 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default need help... alignment problem
I have a fender bender on passenger side last year. shock tower got puished back 1/2inch. well, i had a 2nd alignment done 2 months ago on the driver side and now when i hit a bump or those warning bumps on the road, the front makes a rattling sound? i can't imagine what i could be? anyone with alignment exp. know of anything. help would be much appriciated. also, my steering collum is not centered with the dashboard from accident and when i pull into my driveway, i here a rubbing noise.
Old Mar 8, 2007 | 03:06 PM
anoyone....? BUMP!!!!
Old Mar 10, 2007 | 09:52 PM
monsterbreather's Avatar
what do you meen your steering coulm is not centered??? sound crazy like something is seriously bent!!
Old Mar 11, 2007 | 09:39 AM
DuronClocker's Avatar
Why wasn't the car taken to a frame shop immediately after the accident? Man, even if it was a my-fault accident and the other person told me not to worry about it and just go home...if something was that f***ed up, I would have gone through the whole insurance route anyways to get my car fixed. Frame repair is expensive, if it can be repaired at all.
Old Mar 11, 2007 | 02:54 PM
no, i did. the bumper and fender was messed up. my shock tower was pushed back (passenger side) 1/2 inch. they fixed all that. it drives good, but when i pull into my driveway which is only on a 15degree slope upwards, i feel a vibration from the right front wheel/suspension to the steering wheel. at first i though it was a bad ball-joint until i noticed my steering wheel colum not being centered with the cutout part of the dashboard under the guages.
btw, it was my fault... i was fecking around and hit a dumpster...
