LCA's + Lowering springs = pointless?
I know lowering will give me less traction, so will I be back where I started if I get LCA's and lowering springs? Ive never done any suspension mods so I dont know if one effect is more extreme than the other. Thanks.
What happens when you lower your car is the angle on the LCA changes. Their refenence angle with respect to the road becomes less and that effects the direction of the force vector from the weight transfer under acceleration.
Now, does this mean you need LCA relocation brackets? No. Advisable? Perhaps. It depends on what you plan on doing with your car and how you want to drive it.
Originally Posted by oange ss
need to get relocation brackets
Relocation brackets aren't needed. I have Strano springs and dont use relocation brackets.
relocation brackets, if you get weld in one's if you use your car for the curves you put the lca's in the top hole like stock. if you want to drag you can use either of the 2 lower holes to increase traction. you can do what ever you want to with them.
Sorry everyone I guess I should have given some more information. Yes I would be getting relo brackets as well with the LCA's. Im trying to improve my traction for street/strip racing, not worried about auto-x or anything like that, simply straight line. I am trying to put together a list of suspension, and so far the LCA's and relo brackets are what people have said to start with. The only reason Im asking the original question, about LCA's AND lowering springs is because I would like to lower the car for looks when I get new wheels. I would just like to know from those who know more than me (which is probably everyone) if the lowering springs would hurt what I gained with the LCA's and brackets.
Hope this helps you all understand what Im going after. I haven't done much searching about Strano springs, but are they better than say DMS or the other types of lowering springs? (DMS because Ive seen them in person and love the stance)
Thanks again for your help!
Mine is lowered 1" and I have the BMR LCA's along with some welded in relo brackets... I have no wheel hop at all and it launch's better then stock IMO.
Without the RELO brackets, I had wheel hop and was hard to hook.
