suspension advice
Hotchkis springs 1" drop
Koni's
UMI Bolt on relocation brackets
UMI non adjustable rear control arms(why would you need adjustable?)
UMI shock tower brace
I will most likely buy the Hotchkis and Koni's from Sam Strano. Also Sam if you see this message, whats the difference between the 740$ konis and the 848$ konis? I was also wondering about a sway bar but I don't know.
Demetri
You may or may not need springs. Non-adjust LCA's will help the hopping, but the reason we like to use adjustables are: Non-adjusts bind the suspension in roll, and you can't compensate for the alignment of the rear axle--and they are never 100% perfectly straight. Adjustables solve both problems.
I'd have to say that LCA's would help. You might want brackets, but maybe not, that goes back to just what you don't like about how the car drives and while they help hop, they can also mess up balance. STB--if you want it, but handling wise it's not high on the list for me. Shocks, bars, springs are the big three.
The two sets of Koni's differ in price because the rears shocks aren't the same. Less money gets you shocks that have to be removed to be adjusted into one of 4 settings. More money gets you Koni's that are adjusted on the car, and don't have just the few detented settings. Both work well fwiw, just a matter of how easy/how much adjustment you want.
-Dino
IMO If I were you get the revalved bilsteins, LCA's, and Subframe connectors (welded) to help you get the car off the line, then to reduce body roll get some Sway bars.
-Dino
Lowering springs will help prevent the brake dive and help a bit in the roll department, but spinning on launch will be a little easier. I have no wheelhop with stock wheels, stock LCA's and sticky street tires..unless it rains out??, but that was with a mostly stock setup..I'm not sure if I still get wheel hop when wet. It has not happened since I made some changes.
A good performance alignment, balanced bars, and tire pressures will fix any understeer condition.
Swaybars will help prevent a bit of body roll. I would go with either of the Strano or Hotchkis front 35mm hollow bars, along with a 21mm solid rear bar or 22mm hollow rear bar. The 35mm suspension techniques solid front bar may be cheaper, but is way heavier than the hollow bars and provides the same rigidity. Your lookin at 15 or 20 lbs less with a hollow bar. This won't fully eliminate body roll, but a little body roll is good to have for balancing out the car's handling.
UMI adjustable rear control arms 180.00
UMI shock tower brace 79.99
790
Not bad considering that konis cost this much. How's this setup sound for now? Also Sam, you say you sell UMI products so I will probably be ordering this setup from you soon.
I can't give anything a 100% pass until we talk and I can get a better feel for what you don't like about the car. I don't think this plan is any way bad, I just want to make sure it's appropriate for what you want to change.
