Rear Caliper Bracket Shims
Just a question for those who have installed a 12 bolt. I bought a used 12 bolt and had it redone. It has LS1 brakes on it which is an upgrade for me since mine is a 94 car. Anyway I installed the rotors on it and installed the caliper mounting brackets and found the right bracket contacts the inside face of the rotor. If I install a 1/8" washer between the caliper bracket and the bracket that is mounted to the rearend assy I then have the same distance as what is on the left side.
Is this normal to have to shim the brackets ? I tried to check things side to side but everything looks fine. Any ideas?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
