Brake Bleed Question?
Bleeding break is a different process. You can do this at a different time from changing pads and with tires either on or off (but might be easier with tires off.) You pump the pedal, hold it, and open the bleeder screw to let some break fluid and air out. Close the screw and release the pedal. Repeat until there is no more air coming out.
