C5 brake set-up
Old Mar 20, 2007 | 06:42 AM
Sup foo's Avatar
Default C5 brake set-up
Longe time listener, er, reader, first time poster.
I am upgrading my '97 Camaro to the Corvette C5 Brakes and Rotors. I have all the parts I need, except brake hoses. I want to use steel braided, but they only come in a kit of 4 for the C5. Does anyone know if anyone sells a brake hose kit for the conversion (like front C5 and rear '97 camaro setup). Is there one that I can just buy the fronts or rears?
I do want to change all of them out with the steel braided lines, I just don't want to have to buy 2 kits to do it.
Thanks in advance for your help.
Old Mar 20, 2007 | 10:31 AM
lo_jack's Avatar
There are several places that sell fronts and backs seperate. I believe PFYC (a sponsor) is one of them. Search BYunspeed, tbyrne and Strano parts - those are who I looked at. But yes what you are asking for exists.
Old Mar 20, 2007 | 11:31 PM
Sup foo's Avatar
Thanks for the help. I checked those websites, and didn't find anything. Any other suggestions. I guess I'll continue the search.
Old Mar 21, 2007 | 12:32 AM
GR33N GoblinM6's Avatar
search google for "Kore3"
parts you need are...
C5 rotors (available from checker auto for about 26$ each)
C5 abutment brackets (some call these the caliper carriers) should be 39$ each
brake brackets from Kore3...
Old Mar 21, 2007 | 09:17 AM
VIP1's Avatar
Copy & Paste Moderator
UMI (a sponsor) also makes kits:
http://www.umiperformance.com/c5conv.aspx
Old Mar 21, 2007 | 10:11 AM
Sup foo's Avatar
Thanks fellas. I already have the conversion brackets and calipers and and abutment brackets. All I need is steel braided brake lines. C5 lines for the front and camaro lines for the rear. I'm just having trouble finding someone that carries front only line kits or rear only line kits. I'll try Kore3.
Old Mar 21, 2007 | 12:46 PM
Sup foo's Avatar
Kore3 is hookin' me up. They are gonna make what I need for my set up. Little more than I wanted to spend, but at least I'm getting what I want. Thanks for your help guys.
Old Mar 21, 2007 | 05:49 PM
98ws61le's Avatar
i think summitracing has lines
Old Mar 23, 2007 | 03:53 AM
JasonWW's Avatar
Unless your boiling your brake fluid, regular factory rubber lines are probably your best choice.
