Which shock with the eibach springs?
Can someone reccomend a good shock for the sport kit
I want cornering,handling and will sacrifice ride quality to a degree,drag racing is my last concern...
On shocks, see my post here:
https://ls1tech.com/forums/suspension-brakes/681492-calling-sam-man-all-koni-owners-pics.html
BTW, we also sell springs (Eibach among them) too. And PHB's, and an adjustable one would be wise given the drop of those springs--so you re-center your axle, not to mention it keeps the axle better located, which gives better feel and stability too.
You just lift the back of the car and let the spring stretch out, slip them into place 180* apart from each other and on the same coil and then lower the car. The tension keeps them in place.
