UMI Panhard bar install - with PICS!
Old 10-01-2008, 08:34 AM
UMI Performance's Avatar
Originally Posted by Cumbias
What happens if you over grease the poly bushing??? Does it break open??
Over greasing the bushings will cause them to bulge which will stretch them out and cause the panhard bar to move. We see this to often and stress NOT to do this
Old 10-01-2008, 02:52 PM
-Freak-'s Avatar
Originally Posted by 2002_Z28_Six_Speed
You had to move it a half inch???
Did you match the new panhard to the length of your factory one before installing? A 1/2 is very off...
Yes I matched the length of the stock pan hard bar.
Old 10-02-2008, 03:05 AM
Cumbias's Avatar
So the poly bushing will have greater deflection.
Old 10-05-2008, 04:23 PM
95TAGary's Avatar
can you get this panhard bar in Red? If so what's the part number. I need one soon. Thanks
Old 10-05-2008, 07:54 PM
OffspringZ28's Avatar
yes
i have it in red
go to umi's site
Old 05-22-2009, 07:53 PM
some_punk's Avatar
quick question is the jam nut with the notches in it (the one on the passnger side) the left handed thread one?
Old 06-26-2010, 08:05 PM
mvaldezss's Avatar
tried installing my UMI phb today, though one of the lower spring coils got in the way of the bolt on the passenger side, not allowing me to slide it out all the way. Gonna try again 2morrow when i have more time, but i was wondering if anyone else had this problem.
Old 06-27-2010, 03:41 PM
OlMastaScrilla's Avatar
Ya it is a close fit over there. Just wiggle it or if that doesnt work put jack stands on the body and lower the rear end so the spring is loose and it will come out.
Quick Reply: UMI Panhard bar install - with PICS!
