installing tubular k member with engine in
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
because if you drop the motor, you have a lot more stuff to disconnect. Fuel lines, grounds, wire harness, the tranny comes with it, disconnect the driveshaft, remove the shifter, taking off the torque arm.
UNDER PRESSURE MOD
Originally Posted by DONAIMIAN
I wouldnt trust a STB to hold up my motor while I was under it changing out a K-member.
Why not? You're talking about a 1.5" peice of steel or aluminum holding up 250 lbs. Also, with the trans still connected to the trans brace, it's not holding all of the weight.
When I eventually get a k-member, I'll put the car on my bro-in-laws lift, throw a trans jack under the trans and swap out the k-member. I will put a pair of supports from each head up to the shock tower brace to keep the motor from rocking, but I wouldn't be worried about it falling.
Internet Mechanic
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by Steve Burger
I used a wood 4x4 to support the engine.
Originally Posted by ls1pwrdss
put the car on 4 jack stands all the way up. take you floor jack and a 4x 4 and support the oil pan and the remove the k member. this is how i did it before i had a lift.
Originally Posted by blackbyrd
im surprised no one mentioned using a cherry picker to hold it in place and just drop the k member out the bottom? unless i miss read
When it all comes down to it, its about how safe the person thats working on the car feels. If your fine with a STB go right ahead. Keep in mind a fully dressed LS1 weights 458lbs
I used a cherry picker to hold the LT1 in place and droped the k member out the bottom. Worked great for me, actualy I rented the cherry picker from a local shop and he wanted to sell it so I picked it up on a cheep price.
-Justin
-Justin
Internet Mechanic
