i need some help with part names...
the bolts that hold my caliper in place snapped...whats the name of the two parts that the bolt passes through? i know one of them is a long arm looking thing and the other is what a caliper bracket???
Are you talking about the caliper guide pins that slide into the PAB (pad *something* bracket)?
The caliper guide pins have a female threaded hole that attach the actual caliper with two bolts
oops, I forgot to post this with the pics:
1. Housing, FRT BRK CLPR (Part of Kit 1).........................................NPN
2. Bolt, FRT BRK CLPR Guide Pin (Part of 10, Kit1, Kit2, Kit3) M8x1.25.....(4)...18026153
3. Cap, FRT BRK CLPR Bleeder valve (Part of Kit 1)...............................NPN
4. VALVE, FRT BRK CLPR Bleeder Valve (Part of Kit 1).......................(2)...18029799
5. SEAL, FRT BRK CLPR Bleeder valve............................................. .NPN
6. PIN, FRT BRK CLPR GDE............................................... ....(4)...18026161
7. SPRING, FRT BRK SHOW A/RTL (includes 2 springs) (Part of Kit3)..........(2)...18026181
8. SEAL, FRT BRK CLPR GDE PIN..............................................( 4)...18026151
9. PAD, FRT DISC DRK INNER (Part of Kit3)........................................NPN
10. BRACKET, FRT BRK CLPR (includes 2, 11)
98-02 (J65, EXC Z4C).............................................. ..(2)...18026163
02 (Z4C)............................................. ...............(2)...18046301
11. SHIM, FRT BRK PAD (Anit-Noise) (Part of 10, Kit3) (Includes 4 shims)....(2)...18026164
12. PAD, FRT DISC DRK OUTER (Part of Kit3)........................................NPN
13. PISTON, FRT BRK CLPR (Part of Kit1).....................................(4)...18 026162
14. BOOT, FRT BRK CLPR PSTN (Part of Kit 1, Kit2).................................NPN
15. SEAL, FRT BRK CLPR PSTN (Part of Kit 1, Kit2).................................NPN
Kit1 CALIPER, FRT BRK (includes 1-4, 13-15)
98-02 (J65, EXC Z4C).............................................. ..(LH)..18042491
98-02 (J65, EXC Z4C).............................................. ..(RH)..18042492
02 (Z4C)............................................. ...............(LH)..18046299
02 (Z4C)............................................. ...............(RH)..18046300
Kit2 CALIPER KIT, FRT BRK (includes 2, 14, 15)
Kit3 PAD KIT, FRT BRK (includes 2,7,9,11,12)
98 (J65)............................................. .....................18026165
98-00................................................ .....................18038574
99-02 J65............................................... ..................18026293
Anyway, it looks like it not #2. THose bolt into the slider pins. You broke the bolts that hold #10 on to the spindle. I can't seem to find that anywhere in my little parts list.
