missing strut mounts?
Old Apr 5, 2007 | 06:38 PM
joser the poser's Avatar
Default missing strut mounts?
hey i went to install stock springs with some slp blistens and the guy that did them for me said he could not put them in the front because he says im missing strut mount, holds the strut to the spring, i have the qa1 with hotchkiss springs right now and he said that those work because they are coilovers, those anybody now were i could get this strut mounts ?
Old Apr 5, 2007 | 07:42 PM
mitchntx's Avatar
O'Reilly's .... about $50 each
Old Apr 6, 2007 | 09:15 AM
JasonWW's Avatar
What the hell are you talking about? Do you have a 3rd gen (pre 93) car?
The 93+ cars do not use struts.
Old Apr 6, 2007 | 05:00 PM
trackbird's Avatar
The Bilstiens don't have the spring perch. You are supposed to remove it from the Decarbons and install it on the new shocks. If you don't have your stock shocks, you'll need a set of perches. I have a set of used shocks/springs in my garage right now that have the perches you need. I'd sell them to you pretty cheap, but you're going to have to cut them apart to get the perches off since the top nut is rusted together. Once you cut the shock shaft in half (I'd torch the spring first to take tension off of it), you can pull the spring off and remove the perch for your bilstiens.
Old Apr 6, 2007 | 05:02 PM
yeah i have a 2001 transam, i thought the samething, i think the installer just was an idiot but i dont know, taking to a goodyear or a big o tire maybe they know
Old Apr 6, 2007 | 05:05 PM
spring perch so thats what hes talking about, well i get back to u on the spring perch offer thanks buddy
Old Apr 6, 2007 | 09:14 PM
JasonWW's Avatar
OK, so you mean the lower spring perch that slides over the shock. I've got a pair that came with my Koni's I'll give you.
Old Apr 7, 2007 | 01:27 AM
trackbird's Avatar
Even better. Mine are going to be pretty clunky to ship. If you have loose ones, he should take yours.
Old Apr 7, 2007 | 01:32 AM
JasonWW's Avatar
I think I even have a set of factory ones laying around, too. Does anyone know if the Bilsteins are a different diameter than the Koni or stock shocks? Just to be on the safe side, I'll give you the stock ones if you still need them. I'm pretty sure they will fit the Bilsteins, otherwise Bistein would have included a special size perch with their shocks, right?
Oh yeah, the Koni comes with them because the top hats are too big in diameter to slide them on or off without taking the shock apart. Now I remember. So they should all be the same diameter.
Old Apr 7, 2007 | 11:21 AM
trackbird's Avatar
I think either one will fit just fine. The stock ones are the ones Bilstien expects you to use.
Old Apr 7, 2007 | 11:35 AM
JasonWW's Avatar
That's basically what I was saying.
Old Apr 23, 2007 | 08:42 AM
JasonWW's Avatar
Joser, I can only find one of the stock perches. I tried the Koni ones on the stock shock and it is a perfect fit so I'll send you them. I also just remembered that you will need the hard nylon spring coil cup things as well.
I only have the one to send you. It goes under the spring to make the coil end sit flat. See if you can get another one from the dealer or somewhere.
Do you need these super quick? I can look around and see if I can get another plastic piece for you and send them all together.
Old Apr 24, 2007 | 09:09 PM
JasonWW's Avatar
Hey, I rustled up that other nylon piece. I'll send all 4 pieces out tomorrow.
Old Apr 26, 2007 | 11:12 AM
JasonWW's Avatar
Just got them mailed. Should be 3-4 days.
What are you going to do with the QA1's once you get them off?
Maybe you can do me a favor and take some pics and measurements of them.
