Question about hose mod.
Old Mar 13, 2007 | 12:09 PM
2_wacko's Avatar
Default Question about hose mod.
Do you slide the 5/8 hose around the coil or cut the hose then slip it over the coil? Search is down btw.
Old Mar 13, 2007 | 01:20 PM
Divergent Lightning's Avatar
cut the hose in half and line the top of the spring with the hose.
Old Mar 13, 2007 | 01:59 PM
2_wacko's Avatar
I thought so, I tried sliding it on and it only go's half way even with lube.
Old Mar 13, 2007 | 02:11 PM
Spink's Avatar
Spray some wd40 inside the hose and it will slide on a lot easier, that's what I did.
Old Mar 13, 2007 | 03:34 PM
VIP1's Avatar
Copy & Paste Moderator
Spray silicone can help too.
You can get a yellow can at AutoZone.
Old Mar 13, 2007 | 06:19 PM
FastrDamnit!'s Avatar
yep, grease then twist the heater hose as you slide it onto the spring.
Only do first full coil and leave a little extra hose on the tip to avoid metal to metal if the spring shifts a little.
Also, I remember reading somewhere that the tip of the top coils should be facing the drivers side. Don't know if it really makes a difference but I did this and mine worked out fine.
Old Mar 13, 2007 | 07:15 PM
TheSilverOne's Avatar
spray wd40, silicone, white lithium grease, or any type of lubricant onto the spring
Old Apr 26, 2007 | 11:28 AM
ShevrolayZ28's Avatar
Has anyone had a problem with the hose wearing out? I did shocks and springs on my brother's Cobra and we used a poly hose that came with the lowering kit. Does anyone know where to purchase the poly hose separately?
