I have tried EVERYTHING!!
Ok, so recently I replaced all 4 rotors with duralast rotors, and replaced all 4 pads with Duralast Carbon-Metalic pads. Did everything correctly....but they squeak like CRAZY. I have been battling these things forever. I greased every slide pin, bolt, shim, and even sprayed quiet stop on the back of the pad....no difference. Brake cleaned everything so as not to get anything on the rotor and pad....and yet still i have horrible squeaking. Whats weird though is that it happens mainly when i am driving through side streets and not so much driving on major roads when i dont have to stop as much. That seems to suggest that the squeaking is happening when the brake pads get heated....would that suggest that the pads are my problem? I couldnt see anything else being a problem as i have literally tried EVERY break squeak stopping technique. And help is GREATLY appreciated!
