Does a Firehawk need adjustable PHB, LCAs?
Lotta questions, hope someone can help me out.
I tried the "advanced search" to check through this forum, it kept taking me to some Google page...
My friends Hawk sat at the same height as my Formula.
Regardless, you should not need aftermarket parts for a stock car...
Get the rod/rod or even rod/poly PHR...much better rear tracking and I thick you are still in F-stock class.
Also, Firehawk will be allowed in F-stock with regular V8 F-bods this year for the first time...Lucky you!
Please correct me if I'm wrong.
In any case, that's pretty cool about the A-stock fbods being moved to F-stock. We're gettin lucky with the Evo/STI being bumped out of ESP and now this
I forgot to mention it in my original post, I probably should've just updated the original. The car's my daily driver in the summer so I'm not looking to go too crazy, but I'm OK with trading off a little ride quality for a better-handling car. If you have SFC's installed, then you are already bumped into SM. If you want to keep stock springs, you would benefit from either revalve shocks or konis, a Strano swaybar package, and I'd totally get the T2R differential if I was still on stock power. Dual rod ended PHB is a good upgrade.
If you truly don't want to spend money on the shocks and swaybars given your firehawk set, dual rod phb and T2R by itself would still be a good modification I'd try.
Try all these things first before going to LCA's. LCA brackets would angle your ctrl arms upward and make your rear end more twitchy when taking turns. They are more for straight line launching traction and preventing wheelhop.
A shiny new PHB seemed like a good excuse to wrench on the car for a weekend and since most places seem to offer rod-ended LCAs and a PHB as a package, not to mention the "Canyon Carving" sticky in this forum recommends them, I thought that might tide me over until I had to buy new shocks.
I checked the Strano website and he's got packages that include springs, shocks and a PHB, with a sway bar for good measure - once the tax return comes in maybe I should just invest in one of those and be done with it, I'd probably be buying those components individually over time anyways.
