ARP Wheel stud length question (need answer ASAP, please)
I'm replacing my wheel studs as we speak, but - the new ARP ones are probably a half inch longer than the stock front studs. Should I trim these down with a dremel? I don't think my lug nuts are quite long enough...anyone able to post up some experience?
When I installed ARP P/N 100-7708 I had the same problems with lugnuts. I couldn't find any acorn style nuts which were deep enough. I stopped looking and reverted to the steel open lugnuts from GM and left off the plastic covers. I did need to cut a ARP wheel stud shorter because the threads got messed up, but I'll be switching it back to full length when I replace my hubs soon.
Originally Posted by black_z
I just replaced all 10 of my fronts to run prostars with a little spacer. Grease on the knurling and oil on the threads they pulled through like butter with my electric impact.
What brand and length studs did you end up using? im lookin to use 15x3.5 draglites with a 5/16"
