Has anyone warped Bear Eradispeed 2 piece rotors?
Old 05-15-2007, 04:38 PM
01LS6SS's Avatar
Default Has anyone warped Bear Eradispeed 2 piece rotors?
Has anyone warped Bear Eradispeed 2 piece rotors? I have powerslut drilled rotors. The lasted alot longer than stock but warped after about 25,000 miles. Im looking to upgrade so I want to know if they are worth the almost $400 for 2 rotors. AND, has anyone used the Bear Eradispeed 1 piece rear rotors? How do they hold up???
-Dan
Old 05-15-2007, 05:36 PM
ws6on19s's Avatar
danny i want to know the same....cant be any worse then our powersluts
Old 05-15-2007, 05:54 PM
Imnotfast's Avatar
the anwser is yes to all your questions. Have warped Eradispeed 2 piece but it took a lot of work to warp. Have the rears on the car now and never had a problem. I have found the pad's and how the person drives plays a huge roll on rotor warping. If you brake hard and drive in water or wash your car after a hard day of braking then its hard not to warp a rotor.
Old 05-16-2007, 09:43 AM
greenherb's Avatar
rapid temperature change attributes to warping
Old 05-16-2007, 08:28 PM
hammerhead's Avatar
I have a set of Eradispeeds that are about 5 years old. Recently I started getting wheel shake again so I took them all off and had them checked out. One front and one rear were warped. I had them resurfaced and put on new pads and everything's fine again. I bought a torque wrench that can handle 100 ft/lbs and used it to torque the wheels back on. I didn't do that before, so that may have contributed to the warping.
Quick Reply: Has anyone warped Bear Eradispeed 2 piece rotors?
