good install walk through for tourque arm??
pretty much just have the car jacked up a few feet. Have it suported by the tires very important(ramps or wood blocks). Unbolt old one and bolt up new one. You might also need a good prybar cuz they dont always want to slide right in. Very simple install.
do i have to jack up the front or just the back?
i was thinking that i can put the back of the car on jack stands and use my floor jack
to the hold the rear then move the jack stands and have the car on the jack
and you should never, ever, ever get under a car that is supported only by a jack......it's a good way to have it fall on you and kill you when the jack fails
http://www.installuniversity.com/ins...sity/index.htm
Go there and click on the torque arm bushing install document. That should help you out.
Originally Posted by 02Z28LS1
you're gonna want to have all 4 wheels on a surface to ensure that the suspension is loaded, and they should all be the same height off the ground on a flat, level surface. if the T/A is not adjustable, it won't matter as much if it's level, but if you have an adjustable one, it's mandatory for the car to be level so you can get the pinion angle right
however, once you need to adjust the pinion angle, you will want the car supported by all 4 wheels, at the same height off the ground, starting with a flat, level surface
one thing you'll want to do if it's hard as hell to pull the front mount out of the rubber bushing (like it was with mine) is spray some WD-40 or similar lubricant/penetrant and let it sit for a few minutes....after that, just a nice, sharp tug should be enough to get it to come out. if you need more of a grip, once you get the end that's bolted to the rear differential removed, just put one of the bolts back through the rear hole and put the nut on it to make a nice little handle to pull with.
