Baer/Alcon 4 pot
What are the option for pads. The car is used on the street a lot and some track days.
Does anyone else make rotors that fit? 13.1 x 32 mm.
Here's some part numbers:
EBC: DP2016 Greenstuff, DP3016C Redstuff Ceramic, DP4016 Yellowstuff
CarboTech: 1521 Bobcat, 1106 AX6, 1108 AX8, 1110 AX10, 1112 AX12
Hawk: HB105F.620 HPS, HB105N.620 HP+, HB105E.620 Blue 9012, HB105G.620 DTC-60, HB105U.620 DTC-70
Polymatrix: 15A-5872K "A", 15C-4416K "C", 15H-8113K "H"
Pagid: 1595 backing plate, RS4-2-1 street; RS4-2, RS4-4, RS5, RS14, RS15, RS19, RS29 racing only compounds
For rotors, if you have the Pro kit it uses one-piece 13"x1.125" Corvette ZR-1 rotors available everywhere. Pro+ kits with 13.5"x1.25" two-piece rotors need replacement discs from Alcon; I'm not aware if any other aftermarket rotor disc will fit the center hat. Remember, if you have 1.25" rotors you have to make sure you get 16mm (.620") thick pads; if you get 18mm (.708") or thicker pads they won't fit.
WOW....Thanks for all the great info.
The pads I have now are Ferodo and really like them for light dust. Sounds like the EBC's is what I am going to get.
My rotors are the one piece type and was hopping that it was a common part with the HD brakes on C4's
Will post pic's once completed with the completed set up.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
