Hose mod/ removing rear isolators. Guide
Old 10-26-2008, 05:37 PM
  #61
badmfkr's Avatar
Originally Posted by The Alchemist
Just about every f-body I have seen with aftermarket springs has the right rear lower than the driver's side.
I'm wondering if the factory passenger side rear spring is taller or has a higher pressure.
nice write up FireSilverLullaby.
I'm assumming driver side is a tad higher because the majority of time driven there's only a drivers weight on the high side evening level.also most cars have differnt weight on all four wheels.
I have changed every bushing on this car ( at low speeds it has a sqeak) except these, on my 300zx these booties wore though the spring created a sqeak.These thing look kindoff thick for a spring to wear though?
I'm assumming the ride quaility has harshened some?
When I replaced all my rubber bushings w/ polythuothane ride majorily harshed?
anyone concerned w/ u=joint angle change?
Thanks
Old 01-28-2009, 11:01 PM
  #62
LS1Aggie09's Avatar
i wouldn't be surprised if the ride height is different due to the spare tire. what size hose is recommended for the best?
Old 01-29-2009, 06:04 AM
  #63
UNDER PRESSURE MOD
The Alchemist's Avatar
Well, that can't be the case since I have removed my spare tire, and put a sub box on the driver's side and still have a 1/2" higher stance on the driver's side.
Old 01-29-2009, 06:46 AM
  #64
RsSean's Avatar
Thought the extra spring rate is probally there to compenaste for the torque applied to the rear wheelks under acceleration.
Old 01-29-2009, 07:17 AM
  #65
pjb
pjb's Avatar
as noted in the first post - rotate your rear springs to correct height differences.
Old 01-29-2009, 03:33 PM
  #66
blkZ28mara's Avatar
Noob question here but i take it you lose the isolater after you put the hose on?
Old 01-29-2009, 04:08 PM
  #67
ammuscleftw's Avatar
I am about to replace my stocker shocks and I am torn between the bilstiens and the koni's. I want to but cant lower my car much due to 3" dual exhaust all the way back.. I have like maybe a pop can worth of room to the ground from the pipes. the rear on mine was over 28" from ground to fender in the back and about the same as what ive seen in this post in the front. The gap drives me crazy.. I wanted konis for the front lower perch to lower the front along with the back HH mod on stock springs, either that or Bilstiens and just do the HH mod on the rear.. what do you guys think?
Old 01-29-2009, 04:22 PM
  #68
Formula413's Avatar
Yes. The hose takes it's place.
Old 01-29-2009, 05:24 PM
  #69
Correction.... from the ground to the fender at the middle of the wheel i have 27 1/4" LF 27" RF and 28 7/8 on both rears.. Do you guys think i should just go with the HH mod and use bilstiens with the stock springs or go koni and lower the front and do the HH mod?? a little off topic but im sure a few are wondering the same thing. I was wondering about the HH mod on just the back making it look like the back is squating like others have mentioned.
Old 01-30-2009, 12:12 AM
  #70
blkZ28mara's Avatar
Thanks.
Old 01-30-2009, 09:57 AM
  #71
slow ride 02's Avatar
I would go with the Koni's. That's what I am doing.
Old 08-10-2010, 06:36 AM
  #72
Dougaz's Avatar
sorry for bumpin an old thread did this mod this afternoon dropped almost an inch in the back just wondering if you can do anything for the front springs.
Old 08-10-2010, 07:39 AM
  #73
TRANS-DAD's Avatar
There is really no easy hose mod type fix for the front but your options are koni shocks have a lower perch that you can mount the spring on & it will lower the front (but they are not cheap) or buy lowering springs(gonna still need better shocks) or cut your stock spring(not recomended but with a good shock is not too bad) Good luck w/your choice!
Old 08-10-2010, 03:22 PM
  #74
Dougaz's Avatar
ok well thanks for the reply
Old 08-10-2010, 03:48 PM
  #75
lethal bird's Avatar
I will be doing this hopefully this weekend
Old 08-10-2010, 07:50 PM
  #76
Formula413's Avatar
I actually got Konis recently so I could have used the lower perch on the fronts and done the hose mod, but I decided I want ground clearance more, don't feel like scraping everywhere, plus I can just barely get on my ramps as it is.
Quick Reply: Hose mod/ removing rear isolators. Guide
