Lowering Collector Edition
Also, how do you guys think this will look?
Oh, I was also going to do the calipers in yellow at the same time.
Thanks for the input.
On my Berger SS with the Prokit, The passesnger rear quarter panel is contacting the tire and cutting it up.
Thanks
Paul
1. a +50mm offset on the rims
2. an adjustable panhard bar to center the axle
I've actually rolled the lip of my wheel well to make sure I don't have any contact, but I'm not convinced this was necessary...
good luck,
Shane
However, I know the TTII's (that I already bought)have a 46mm offset on the rear 17x11 wheel. I should have ordered the custom TTII's with +50mm.
Does the lowering package make a difference as to the amount of offset? I wouldn't think so as the offset is the measurement of depth, not height, or am I not making sense?
What springs are you running?
Paul
Hotchkis sells a 1" lowering kit. I am personally running the SLP Performance Parts Level 1 Eibach Springs and am pretty happy with the drop.
Now your other question in your last post, the "offset" is only related to how the wheel is going to be placed "in" the wheel well. A 46mm offset is going to put the wheel further out of the wheel well compared to a 50mm wheel, thus with a lowered car would increase the changes of the tire contacting the wheel well lip. If you go with the Prokit and the wheels as you describe, I can say you will have contact problems, and will have to roll the fender lip. Like I said before, my Berger wil the prokit, and 37mm offset 17" x 9.5" wheels the rear tire hit the body work, nad is f'ing up my tire.
Thanks for all you advise.
Paul
Number one is a Bright Rally Red Convertible SS that I modify by myself, I have installed the SLP Performance Parts Level 1 Eibach springs in my SS. As for what the "1" truely stands for I do not know, but the springs do lower the car ~3/4" to 1". As a side note I went one step further, I wanted the front of the car to sit about 1/2" lower in the front (more) so I cut half a loop off the front spring. I am running 18" x 9.5" w/ 275/35YR18 front and 18" x 10.5" w/ 295/35YR18 rear with absolutely NO problems. Here is a recent pic.
My other SS is a Berger SS that is lowered with the Eibach Prokit, this car is the one that I am having problems with the passenger side rear tire making contact woth the body of the car. I am still running 17" x 9.5" wheels but the offset is pretty small so the wheels are pushed out a little more than stock, but not as far as an 11" wheel. Here's a pic.
I hope this helps. I see you are from Chi Town. Are you in Chicago proper or more of a suburb?
