Removing Spohn Torque arm..Which next?
Old May 29, 2007 | 04:56 PM
zapp168's Avatar
Thumbs down Removing Spohn Torque arm..Which next?
I have had it!! I keep bending the floor back, but it just keeps banging! The extra noise, the bolts loosening up, and I slam something every day...just too low...and Just not worth it, I would rather have the wheel hop!
Anyone running a moser 12 bolt and happy with their adjustable Torque Arm? I am going back to the stock one for now. The wheel hop problem was 100% solved, but the everyday driveability has suffered too much.
Old May 29, 2007 | 05:06 PM
DuronClocker's Avatar
I like my UMI one very much I don't however have a 12-bolt, but I am using a Moser 9" housing with their torque arm bracket. There was one spot that was close to hitting, but I just gave the floorboard a couple small "love taps" and re-undercoated that area and no problems.
Old May 29, 2007 | 05:24 PM
sdbrown84's Avatar
No Moser but no troubles with the BMR. Ground clearnace is fine and no "rattles" other than a problem with my QTP's hitting my K.
Old May 29, 2007 | 05:55 PM
JR Newman's Avatar
I have a moser 12 bolt w/Spohn adj. arm, how low is your car, my drag car (84' firebird), from the frame connectors is about 5" off the ground my T/A is no where near the ground, my headers,trans. pan,exaust would hit first. JR.
Old May 29, 2007 | 06:33 PM
zapp168's Avatar
My car is stock height, the arm itself is not near the ground, the crossmember where it mounts is. Here is a pic. it is a 405. The wrapped exhaust is passing through it
[IMG][/IMG]
I catch my driveway all the time, and yesterday I SLAMMED it at a gas station on the underground tank fill, it was a little high and the ground around it was a little sunk, and I thought I ripped something out of the car!
SpdFrk1990's Avatar
You might want to look into a umi relocation kit I got one and it helped alot and it uses stock length torque arms.
Old May 29, 2007 | 06:36 PM
zapp168's Avatar
Does it just relocate where the Arm mounts? And does it work? I had a HORRIBLE wheel hop problem before this! The arm solved the problem, If this was a track only car it would be fine.
Old May 29, 2007 | 06:45 PM
SpdFrk1990's Avatar
I had horrible wheel hop too till i got some lca's and this TA relocation. I also did springs and shocks too. I use to get bad shifter shake on the 1-2 shift and its gone now plus no more wheel hop.
Old May 30, 2007 | 10:24 AM
zapp168's Avatar
SPDFRK That looks NICE....are you using the stock arm?
Old May 30, 2007 | 11:32 AM
SpdFrk1990's Avatar
Yes I am.
Old Jun 7, 2007 | 11:51 AM
Z28Streetwimp's Avatar
The relocation bracket looks pretty stout, but there is not exhaust system in the photo. Sig says you have true duals....are they above or below the torque arm relocation bracket? Maybe it's just the angle that the picture is taken, but it doesn't look like there's room between the relocation bracket and the body for much of an exhaust.
My car came with a TA is a custom fab job that mounts to a diagonal brace that ties in the SFCs and the tunnel brace, so the TA is nice and short, but there is no linkage to allow fore / aft movement. As a result, it's noisy and I've worn the bushing out because it's had to create it's own clearance for fore /aft motion. I'm sure the suspension is binding also, as everything else is BMR with poly bushings - except I went back to rubber on the front LCA mounts as a short term action to allow for some give while I figure out what I want to do. I am leaning towards the UMI tunnel brace mounted piece, but I'm lowered (BMR springs) and I have LT headers, ORY and TSP Rumbler so I need to get the bracket that is clearanced for the exhaust, and I'm worried it will be too low and I'll drag it all over Charleston!
Old Jun 7, 2007 | 03:01 PM
SpdFrk1990's Avatar
I have a kooks ory and a magnaflow catback there is plenty of room. There is also someone on here with the same relocation bracket and true duals.
Here is a pic of my y-pipe.
Here is a pic of DVST8OR's true duals with the same relocation bracket.
Old Jun 9, 2007 | 04:54 AM
EPP's Avatar
EPP
Smile
The BMR torque arm's are much quieter than the Spohn. Bob
Old Jun 10, 2007 | 02:32 PM
omcar's Avatar
I have a Random Technology torque armm..works great
Old Jun 10, 2007 | 07:59 PM
zapp168's Avatar
I ordered an UMI bar, I spoke with the tech guy, he suggested with my setup to go with the complete arm, says it is quieter than the Spohn....we shall see
Old Sep 4, 2007 | 12:09 AM
Swampdog's Avatar
zapp168 did the UMI bar solve the banging. I have Spohn and it bangs thru every gear.
Old Sep 4, 2007 | 08:59 AM
BURN'EM's Avatar
I have the Spohn with cross member i freaking hate it! I'm not lowered just have a large Ypipe and the bitch is banging like a screen door in a hurricane. I can't get it to stop.
Old Sep 12, 2007 | 01:00 AM
westxwitesnake05's Avatar
had the same sh!tty spohn torque arm and went with the bmr full length adjustible t/a and thier relocation kit and i love it!
