PHB Bushings/ Rear Isolator Questions
Search is broken in Iraq... sorry
I have a rod/rod phb and it makes alot of noise over bumps. Are there bushings to replace the metal spacer on the bolts? If so, where can I get them?
I'm getting springs and shocks from Sam in August and wanted to know if there is a a rubber piece that covers the whole spring or a smaller rear isolator that can be bought, other than the heater hose. If so, where can I get them?
my phb is doing the same, a lot of clunking, the manufacturer tried to say it was the end links but i have those torqued down to spec and the clunk is coming from inside the bar it seems like
