Road course and autoX setups
1. 1" drop springs from Eibach.
2. 32mm front sway and 21mm rear sway from BMR.
3. etc...
Thank you.
It's more about driving style, skill and comfort level than hard parts.
Some people like heavy front springs and a light sway bar, while others like soft springs and a massive sway bar. Each seem to work for a driver's particular preference.
For a starting point on a road course, I like a #550 front spring and Bilstein shock with a 1LE (32mm) front bar which works very well for me. I can take or leave the STB ... saw no real handling difference. Boxed subframes so that I can jack up the car and poly/rod LCAs and poly/poly APHB.
I have Koni SAs and a progessive spring out back because if I bottom out the suspension, I have infinite spring rate. That's bad.
To reduce wheel hop on acceleration and braking I have G2 torque arm. None better, IMHO. Adjustable TAs work great for acceleration but will kill your rear end on braking because of the massive wheel hop.
Tires ...
Hoosiers are fantastic for about 3 or 4 hours of track time.
Kuhmos last 10 times as long and are good during the first 1/3, great during the 2nd 1/3 and greasey during the last 1/3 of their life.
Nittos are spongey during the first couple of heat cycles, but then become very consistant for the rest of their tread life. The last about as long as the Kuhmos ... maybe longer.
Brakes ...
Aggressive pads will make the car freaking STOP ... but at the price of your rotors. Get pad friendly rotors and the car has to be babied quite a bit. And your brake fluid will cook, so it will need constant service ...
PITA, ain't it .... but all that pain goes away when you run down and pass a 911 or M3 ...
I've an '02 TA and would like to continue to go to the road course. The instructors all say to disable the ABS for the track. I've run across other "FBody" heads who indicate the ABS controls the brake proportioning valve. If the ABS is disabled then you've disabled the computer controlled ABS Pro. Valve and introduced increased rear wheel braking, not a good thing. Is there any solution to this issue and achieving the desired "non abs brake" system I'm after.
Best Regards and thanks for your insight
Steve
If you are getting a LOT of wheel hop on braking, then I would think that ...
torque arm is flexing/binding
LCAs are binding
too much forward weight transfer
too much brake pedal
1 or a combination of them is the likely culprit, all based upon my limited knowledge and experience.
I have the G2 Non Adjustable torque arm on order. I'll hopefully have some feedback in the near future. Not for this w'end however. In the Mid Atlantic it's set to be a rainy w'end.
Steve
This equates to slow in, smooth transition, and fast out. You will be smoother and faster than waiting till the last possible second to brake.
On the gas means weight transfer to the rear and more rear grip. 9 times out of 10 one loops the car because of unloading the rear of the car ... I can speak from experience ...
3. etc...
Thank you.
The rest is just icing on the cake . . . One suggestion they gave me prior to receipt of the parts was to safety wire the mounting bolts at the rear end. I was able to get a new set of them and had the heads of the bolts drilled at a machine shop and obtained the wire to hand the whole package to the installation mechanic. It went very smoothly.
Regards
Steve
Bar none, they make the BEST suspension components to make an F-Body handle.
Hotchkiss Springs
Bilstien HD's
Hotchkiss Sway Bar Set (TBYRNE)
Global West Tracklink (its a torque arm)
Kenny Brown DD SFC's
Hotchkiss LCA
Hotchkiss PHR
Lightweight Kmember
MBR Upper and Lower Control Arms
A LOT of alignment changes lol
275/40/17 A032R's front
315/35/17 AO32R's back
Wolfe Six Point Roll Cage
No seats except driver seat (Sparco racing seat with kidney support)
Let me tell you this thing handed a LOT of vettes and Porsches their ***, but then again let me give you a BIG piece of advice "DRIVER MATTERS!!"
