is this upper shock mount still good?
Old Jul 10, 2007 | 06:47 PM
qwikz28's Avatar
Default is this upper shock mount still good?
notice the crack in the rubber where the shock bolts into?
Old Jul 10, 2007 | 06:55 PM
ROCNDAV's Avatar
I'd replace it.
Old Jul 10, 2007 | 10:20 PM
67rsss's Avatar
No. Replace it.
Old Jul 10, 2007 | 10:55 PM
qwikz28's Avatar
thanks guys...
what are you guy's thoughts on those non-oem ones from napa?
Old Jul 10, 2007 | 11:50 PM
ROCNDAV's Avatar
Originally Posted by qwikz28
thanks guys...
I didn't even know they made them? How much are they?
I was thinking of making my own mold and pouring some polyurethane in, but never got around to it. My neighbor did his own motor mounts that way.
Old Jul 11, 2007 | 08:37 AM
qwikz28's Avatar
its actually some other reject company that sells through napa. the napa ones are $80 as opposed to GM $170.
if you have the ability to do a polyurethane one i don't know whats stopping you. i would donate my old oem ones to you if you like
Old Jul 11, 2007 | 11:25 AM
trackbird's Avatar
The ones we bought at NAPA were IDENTICAL to the stock ones. Every scratch, bend, weld, etc. The ones we bought elsewhere were not and we didn't have much luck with them.
Old Jul 11, 2007 | 12:30 PM
98redM6's Avatar
I got aftermarket KYB mounts when I first got my springs installed. They were like $50 each or something through summit.
Old Jul 11, 2007 | 03:35 PM
qwikz28's Avatar
i'm geting the napa ones then. thats what i needed to hear. thank you very very much.
Old Jul 11, 2007 | 03:42 PM
ROCNDAV's Avatar
Do me a favor and post up the Napa Part number after you get them. THe Napa stores around here have worthless employees.
Old Jul 11, 2007 | 11:03 PM
trackbird's Avatar
I remember that it was about $89, but it was well worth it after putting on a different one and having the threaded insert strip and having to tear it down and do it twice. Make sure the threads are steel and not an insert that's set like a rivet. The steel threaded ones are the good ones.
Old Jul 12, 2007 | 07:38 AM
qwikz28's Avatar
to the best of my knowledge they are steel threads. i don't really know how to tell. but the whole piece feels quite solid. the part numbers for left and right are 261-3195 and 261-3196 and the rubber insulator (bearing thing) that mounts on top is 261-3197 which is universal for either side.
Old Jul 12, 2007 | 08:56 AM
trackbird's Avatar
The "other" one we used had aluminum threaded inserts that were punched into the holes. Many people say they work fine, and they might. We had problems with the bolt holes being off and the bolts went in something other than straight and then stripped the inserts (the inserts began to spin in the mount).
Old Jul 12, 2007 | 09:37 AM
qwikz28's Avatar
they are in fact steel. assuming aluminum isn't magnetic i put a magnet to it and it stuck. so i take it these are the the good ones
thanks trackbird
Old Jul 12, 2007 | 10:13 AM
trackbird's Avatar
Sounds like it.
Old Jul 12, 2007 | 02:28 PM
Blakbird24's Avatar
Restricted User
I paid $48 for one through carquest that is much beefier than the stock one it replaced. I was tempted to get one for the other side even though I didn't need it.
Old Jul 12, 2007 | 07:21 PM
VIP1's Avatar
Copy & Paste Moderator
Correct. Aluminum is not magnetic.
