ABS/TCS removal
Old Jul 12, 2007 | 01:16 PM
warp10's Avatar
Default ABS/TCS removal
Beside the black tape mod, does anyone know how to remove the ABS and TCS indicator lights when you do the !ABS and !TCS mod?
I heard that some fuses can be pulled but I'm not sure which ones.
Old Jul 13, 2007 | 10:52 AM
warp10's Avatar
no one?
Old Jul 13, 2007 | 05:13 PM
DuronClocker's Avatar
I pulled the cluster, figured out which solder points on the back of the board were for those lights, and cut the PCB traces for them.
Old Jul 14, 2007 | 06:44 PM
great421's Avatar
There's a wire off the module (in the dash) you can ground to resolve this, SJM (a sponsor) knows the one.
Old Jul 16, 2007 | 12:00 PM
warp10's Avatar
That would be great. THX
Old Jul 16, 2007 | 01:58 PM
jimmyblue's Avatar
Moderator
I've always wondered what happens if you just disconnect
the TCS "brain" up under the dash. Because non-TCS cars
don't light that light.
Old Jul 16, 2007 | 04:42 PM
I believe it is BCM-controlled however. The BCM gets a signal from the TCS box and then decides what to do with the TCS light in the dash based on that input.
I've heard you can get a BCM out of a non-ABS/non-TCS car, and it will eliminate the lights as well, but I have no idea the other specifics about swapping a BCM.
Old Jul 18, 2007 | 01:56 PM
warp10's Avatar
Sounds like a good idea but the only option I see from GM are BCM's with or without wireless key entry. Nothing with TCS or ABS stuff.
Old Jul 18, 2007 | 09:28 PM
oneBADDz's Avatar
Are there on ABS cars though?
