QA1 adjustment question
I am looking at buying the QA1 single adjustable front shocks for my T/A. I want to do this so that I can raise my ride height about 2" from where it is now for when I put on the skinnies for the drags and then be able to lower them back down to where my stock shocks with DMS springs are now (approx. 1.75" lower than stock). My question is is there that much adjustably in these shocks to do this? TIA
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
yes, i would think so. I have mine setup a little lower than stock and have plenty of adjustment room above it. Im not sure how it will play out with the DMS springs. Just be sure to buy a good spanner wrench and the thrust bearing kit. I would recommend using the stock springs. Modification is needed to the spring seat, you should be able to do a search and find the info needed for the use of them.
