Chromoly 3 Point Sfcs
Does Anybody Make A Chromoly 3 Point Sfc?
I Have The Slps (mild Steel) They Are Definately Beefy But Also Very Heavy
If Someone Had A Simlar Design But Made Of Chromoly Id Switch To Save The 20-40 Lbs And Keep The Same Regidity
**please Dont Reply With Links Of Info On 2 Point Sfcs I Know All About Them**
-john
-john
The SLP SFC's actually only weigh in at 36lbs, our 3-Point design is about the same at 35-36lbs per set.
I sat down awhile back and calculated the weight savings using a weight per foot calculation and a set of ours would weight in 9lbs lighter then mild steel if built out of Chrome Moly. For the price tag we would need to charge for this item at of chrome moly we scratched the idea.
Hope that helps,
Ryan
Hope that helps,
Ryan
