What LCA for Auto X?
Old May 28, 2003 | 06:40 PM
2000Z28M6's Avatar
Default What LCA for Auto X?
What should I look for in a LCA for auto X? What brands have proven them self at the auto X scene? Which one will give me a bit of both worlds drag and auto X? I dont care about noise. I would really appreciate the comments.
Old May 28, 2003 | 09:15 PM
mitchntx's Avatar
Default Re: What LCA for Auto X?
G2 poly/rod
Old May 28, 2003 | 09:19 PM
2000Z28M6's Avatar
mitchntx are you quoting some one or you know first hand? Is this whats in your car? Can you list your suspension setup.
Old May 29, 2003 | 12:08 AM
absolut_speed's Avatar
Why would you want to swap them if you're interested in autocross? LCA's will bump you out of the ESP class.
Old May 29, 2003 | 06:45 AM
Viper's Avatar
G2 poly/rod
See sig for mods. I've tried 3 other LCA's; these are THE best period.
Old May 29, 2003 | 07:30 AM
mitchntx's Avatar
My setup:
LGM -
Torque arm
Springs (replaced my sagging Eibachs)
poly/rod LCAs (replaced my BMR poly/poly which replaced Hotchkis junk)
APHB (replaced my noisey BMR)
4pt roll bar
Bilstein shocks
1LE sway bars
BMR sub frames
Prospeed Brembo brakes
17x11 GS wheels on all 4 corners
Old May 29, 2003 | 09:23 AM
2000Z28M6's Avatar
mitchntx how does the 4 17x11 work? Does the front rub any? I'm really intrested in your set up. Any chance I can see a pix or your ride?
Old May 29, 2003 | 10:38 AM
trackbird's Avatar
I autocross on the BMR Heim/Heim LCA's....but will either be designing my own or buying LG motorsports to try very soon. My mods are in my sig....
Old May 29, 2003 | 12:02 PM
mitchntx's Avatar
I have to run a 1/4" spacer up front and had to grind off a raised portion of the spindle that looked like some casting relief. It was not structural.
And I had to roll the fenders in the rear ... not because they rubbed, but it was too close for me to be comfortable with.
Here's some pics ...
Old May 29, 2003 | 12:41 PM
Viper's Avatar
Nice car!
Old May 29, 2003 | 01:46 PM
2000Z28M6's Avatar
Man that looks ******* Great 4 17x11s what size tires you got on those rims? I like the setup I think your the first 1 I seen with this set up. Does it handle like it looks?
Old May 29, 2003 | 02:22 PM
mitchntx's Avatar
Thanks ... appreciate it ...
I'm running 315 Nitto DRs. I had it very neutral with 275 Nitto R2s. I ran a couple of 60% sessions to shake it down and car seemd to pick up a bad push.
However, Nittos tend to be kind of greasy until a few heat cycles are put on them.
Going to Texas World Speedway this weekend. So, we'll see.
By Brett Foote | 2026-06-04 05:00:17
