I want to hook like crazy on dr's!
How about telling me how to hook up my m6 on drag radials. Currently they are Bfg's that may change. But my goal is to remain a drag radial car. I have edelbrock lca's. That's it for suspension mods. I have a 12bolt and a clutch too.
Re: I want to hook like crazy on dr's!
YOu may want to move this to the drag racing forum....but...
I'd set you pinion angle at -1.5 degrees (with an adjustable torque arm) and look into a set of aftermarket lower control arms with matching relocation brackets. YOu will have to experiment with which hole in the relocation brackets will work best for your car. After that, tune your tire pressure for the best launch....good luck!
