Rear Brake Replacement Question
It had significantly cut down on the pulsation during hard braking, but my car still vibrates during hard braking, and now if feels like it is coming from the rear only.
Should I just go with AIMCO rotors and OEM pads again for the rears? Is there any tirck to changing out the rotor/drums on the rear? Thanks for any info...
Tommy
Suggestion: replace EVERTHING that is subject to wear...
ever
Tommy
Tom,
Before buying entirely new rotors I would maybe have them checked and turned (machined) it will save u a ton of cash. I own a 1998 Z28 and can vouch that the brakes on these cars are crap, and expensive to replace i.e. new rotors. However, GM did make it very simple to change out pads as you may know. For the rear brakes, your parking brake system will run interference. As you may or may not know is basically a drum brake within your rear rotors. The shoes on the parking brake are a pain in the *** and make it difficult to remove the rear rotors, due to them pushing out onto the inside wall of the drum inside the rotor. For some reason the adjustment on the wheel cylinder for the parking brake to retract the piston is only accessible once the rotor is off **shrug**.
I used a rubber mallet and a lot of swearing to remove my rear discs. I also removed the parking brake cable from the back of the wheel cylinder to ensure that it was not putting any pressure into the system.
Tom,
Replace them.
