rebuilding calipers seals fronts and rears?
ok i got the info for rebuilding the front calipers seal kit gm# 18026160 but what about the back calipers are they fixed the same way? its a different part number right rear gm caliper seal#12530687 anybody know if you fix them the same as the front or what??
I don't know for sure, but if I were going to do it, I'd probably just use the same procedure.
Did you use www.installuniversity.com?
Copy & Paste Moderator
http://www.installuniversity.com/ins...er_rebuild.htm
I just rebuilt all my calipers today. The rears go together the same as the front. #12530687 is for the rears. Unlike the front you only need 1 kit for each caliper. It was really easy to do and didn't take long
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
For the caliper rebuild kits? You got ripped if you spent that much. I spent a lot less for the rebuilt kits for all 4 calipers. I can't remember exactly but I think it was around $60
