Tunnel Torque arm w/ FLP Y-Pipe?
I'm looking at the UMI tunnel mounted torque arm.
I'm using FLP LT headers and Y-pipe which hang down a bunch from the tunnel mount.
Has anyone used this combination?
Thanks....
Thanks....
This is the picture in the catelog. My FLP - Y-pipe hangs much lower than the one in this picture, however.
http://www.umiperformance.com/images/2200j.jpg
Hello,
We have had customers use our tunnel mounted torque arm with a FLP set-up and no issues. However you will need to use one of our versions designed for long tube headers. Either one in the links below should work just fine.
www.umiperformance.com/2202
www.umiperformance.com/2203
If I can help anymore please ask. Thank you!
Ryan
Ryan
