I'm bleeding - need help!
Apparently. from the criptic directions this is a device that can be used to SUK brake fliud from the brake calipers. (I was hoping it could be used to force fluid "up" from the caliper to the master, however. - Oh well!)
1. Can bleeding brakes with the Myti-Vac be done with a single person?
2. Do I need to de-press the brake pedel to get fliud to move from the caliper to the master?
3. Are there any other issues that become apparent from using this device?
Thanks,,,,,
and some barb fittings and pipe-thread nuts. Then it's pretty simple,
crack the bleeder about half a turn off the seat (threads don't suck
air but fluid can come out), put vac hose over the nipple and go at
it baby veal cow style. When the fluid runs clear (presuming it's now
a crusty brown, though this is just how my beaters are by the time
I change fluid) you're done, tighten it before the fluid lets a bubble
back.
2. See above, Mity-vac pulls the fluid through no need to pump the brakes
3. See 1.
