If you had $1200 to spend on a stock-suspension '02 TA.
LS1TECH Sponsor
But the bottom line is that a suspension is no different than an engine in that it's all a bunch of parts that each do a job, but also have to match. If you were building an engine, you could pick a bunch of cheap Summit parts and slap them together. You could buy more premium parts on your own and slap them together. Or you can get a ready to go system that's been proven.
__________________
LS1TECH Sponsor
FWIW, if I had $1200, I'd start with Koni's (and you have options here) and a set of swaybars first. That's $1119-1227 depending on which set of Koni's you pick.
You could also consider the shocks with our springs ($1009-1117) plus an adjustable PHB which runs $109-179 depending on style.
No matter what, shocks are the key. And things like SFC's, LCA's, relocation brackets and so on are secondary items to springs, shocks and bars.
__________________
Listen to Sam he is the man.
Here is what I think for my experience.
Stock springs
REvavles
front and rear bars (sams)
Double panhard bar 179.99
or
Konis
front bar
add rear bar and panhard when you get time
I really like the konis better, but the bars are very nice also. I would proably just get konis and you can add the others when you get money later. the PHR helped a lot that I didnt think it would.
Stock springs
REvavles
or
Konis
front bar
