C5 vs Fbody rear pad Abutment bracket
I bought a set of brackets from another member and had them powder coated. I went to put them on the car and I can't get the pad to go into place. It looks like the pad is just a little too big. I can get it into place if I tap it but then it's in a bind. I know if I tried to use it the brakes won't work correctly. Is it possible that they might be C5 brackets?
The powder coating wasn't put on thick enough to cause a problem. The front set went right on without a problem. I didn't check both rear brackets as I was short on time and when I hit this problem I called it quits for the day. Its really a tight fit there's no way the coating was put on thick enough to cause this much trouble. It's got to be something with the bracket
You could walk into a local parts store and ask to see a set of pads for a C5. See if they fit. Or, I've had some rear PAB's that were pretty tight. A few mils of powdercoating could have made them too tight (on some of the ones I've seen).
