Koni SAs/Stock springs/Upper Perch???
I have searched and have not found an answer to this question however I am sure it is out there somewhere. I don't post much because I usually find the answers. Anyway. If I install Koni SAs with the stock springs on the upper perch setting will I be at stock height? Will it still be advisable to get an alignment either way? Will there be a noticeable compromise in handling with using the upper perch? I appreciate any help. Thanks!
Can you describe the improvement vs. stock shocks. I think most people who run the Koni SA's also run lower springs. Like the original poster, I interested in running stock springs with Koni SA, but want to get an idea on the improvement in handling.
What about the improvement from Stock spring/Koni to Sam's springs/Koni?
Thanks.
Thanks.
Thanks.
Thanks.
https://ls1tech.com/forums/showpost....25&postcount=4
Your car will feel like a real sport car should.
