View Poll Results: STB make a noticeable difference?
YES
44
49.44%
NO
45
50.56%
Voters: 89. You may not vote on this poll
STB make a difference?
Old Nov 11, 2007 | 01:01 PM
mikenews's Avatar
Default STB make a difference?
Hello all, did u notice a difference in your car after installing a stut tower brace? Please vote only if u have one not from what you read or have been told. Thanks
Old Nov 11, 2007 | 02:58 PM
_JB_'s Avatar
Only slightly over bumps and turning at the same time. Other than that, nope.
Old Nov 11, 2007 | 03:14 PM
00SS!'s Avatar
Me too!
Old Nov 11, 2007 | 04:39 PM
MeentSS02's Avatar
Kleeborp the Moderator™
100% YES. My engine bay looks much nicer now with the STB Gives me a good place to put my hand too when I'm working in there...
Old Nov 11, 2007 | 04:50 PM
_JB_'s Avatar
Gets in the way sometimes to lol
Old Nov 11, 2007 | 04:52 PM
MeentSS02's Avatar
Very true
Old Nov 11, 2007 | 06:15 PM
jimmyblue's Avatar
Moderator
On my convertible it settled down a front end shake that
would show up on hard cornering. Dunno about hardtops.
Old Nov 11, 2007 | 08:12 PM
Mojave's Avatar
Shock tower braces (f-bodies don't have struts, so no strut towers) are good to lean on when under the hood. Otherwise, don't improve performance at all. I don't think anyone has proven that shock tower braces actually make a car faster (by prove, make back to back runs on an auto-x/road course and see a definite reduction in times).
Old Nov 11, 2007 | 08:17 PM
Ace$nyper's Avatar
Looks and mental mostly, some argue they notice it, on a sturdy car like the F-body I have my doubts it matters at all.
Old Nov 11, 2007 | 09:53 PM
Wild Willy's Avatar
I put mine on a day before I mounted the SFC's- didn't notice the STB much, but I think the SFC's firmed thinkgs up a bit-
Old Nov 12, 2007 | 02:16 AM
nighthawk15's Avatar
Maybe it's all in my head, but I thought it made the front end feel just a bit tighter.
Old Nov 12, 2007 | 07:21 AM
InsaneAuto86's Avatar
I noticed a small difference too. I bought it mainly for appearance.
Old Nov 14, 2007 | 01:21 AM
LebaneseShowoff's Avatar
+1... it completes the engine compartment.
Old Nov 14, 2007 | 10:39 AM
leadfoot4's Avatar
I installed a STB and a few months later, a set of weld-in sub frame connectors. I didn't notice any big difference, but I drive the car everyday, and just get used to things. A friend rode in the car a short time after both were installed, and he said the car appeared to be tighter, at least in his opinion.
Old Nov 14, 2007 | 11:19 AM
Ericbigmac83's Avatar
I noticed a difference with mine, nothing major though. But its a cheap part and it cant really hurt anything. i didnt put mine back on though after i threw in the new engine
Old Nov 14, 2007 | 02:12 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I've wondered the same thing as well. I guess the easy way to tell would be to put a two peice bar in spanning the shock towers where one end slides into the other end, something like a piston and sleve. Then take a spirited drive and check to see if there are any signs of the piston flexing in and out of the sleeve. If there is flex, then the shock tower brace is working, if there is no flex, then it's an expensive peice of engine jewelry.
Old Nov 14, 2007 | 04:54 PM
Ironhead's Avatar
It's been done.
More than one engineer type person has attached strain gauges to a 4th gen STB and found that there is almost no force being transmitted.
This makes a lot of sense if you take a step back and think about how the 4th gen front suspension works.
Old Nov 14, 2007 | 05:24 PM
Mojave's Avatar
Originally Posted by Ironhead
It's been done.
Exactly. It has been done for a lot of cars, and as far as I know, no one has found significant movement on the front shock/strut towers. OEM's aren't stupid; they know what loads are being transmitted to the chassis and what it takes to properly support them.
Old Nov 14, 2007 | 05:57 PM
UNDER PRESSURE MOD
OK, so there you have it.... it's engine jewelry....
Old Nov 14, 2007 | 10:58 PM
ssgunny's Avatar
I have a friend who actually removed his front bumper brace for weight savings and while drag racing the front of the car twisted like a ****. He thinks a STB would help if you did a mod like this. I will have to double check to see if I got the story right.
