Will ABS work with 28'' Tires
I have some 28'' tires on the rear and 26'' upfront and just went to the tuner to have him correct it in the computer and he calibrated it for my 4.11 gear and the 325/50/15's and I still have the damn abs inop light on. I hate driving it and every time I hit the brake pedal their resistance from the abs in the pedal. Also it stops a lot shittier than it did before.
Is there any way to correct this???
No it will not work. Our ABS delete kit may be your best solution. It will also clean up quite a bit of space and lower your front end weight a bit.
Good luck, let me know if you have additional questions or concerns. E-mail would be the best method of contact as I am not on the boards as often as I check e-mails.
