LGM springs or Eibach sportline lowering springs
1 Post
A word of advice, do some serious research before you buy. Search through the suspension section and read read read. And a quick FYI, unless you don't care about ride quality, feel, and replacing shocks often, you will need a good shock package that can damper the lowering spring you get. The stock ones on our cars struggle to damper the stock springs. You know that floaty feeling at higher speeds you get? Thats from the stock shocks. And you're not going to be able to buy shocks over the counter that are able to damper any lowering springs for our cars, so don't waste your money there.
yea i know ur absoulutly correct!! i also found out that i must readjust my panhard rod as well and as for shocks, i was thinking of some good kyb shocks, because i dont want to waste to much money for appearence as i can enhance my performance with the same costs, but the previous owner b4 me gave me a extra set of brand new factory shocks, but i hear the factory ones suck lik u said as well,
https://ls1tech.com/forums/showthrea...yb#post7248592
Look into either Koni SAs or Strano revalved Bilstiens at stranoparts.com.
1 Post
humm i thought kyb was one of the real good brands, well enyways for shocks, i guess this whole lowering thing is gonna cost wayy more then i thought, what do u think of the factory optioned bilsteins? do u think there junk or jus not good enough, well im gonna look into shocks and if i can find a god deal on em i will buy the shocks b4 i buy the springs or jus together but thanks alot 4 the info i really appreciate ur help
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The stock DeCarbons are crap...period. Have you looked at BMR springs? Check out Strano's website, or contact him. He could probably point you in the right direction.
Insofar as my 2-inch drop, I have Hooker LTs and will rarely scrape them. Then again, my Z28 isn't a daily-driver and I am pretty careful...
And the Bilstien HDs are also meant to damper only the stock springs, so they wont give you what you need for lowering springs.
Like said above, give Sam a call he can fill you in on anything you need to know about suspension.
