Is aftermarket TA needed?
I have new BHD shocks, rod/poly LCA, PHB, Strano bars, new tires on a 99 F-body street car.
These mods greatly reduced wheel hop and the car corners MUCH better!
On rare occassions, I get a rude shudder from the gear box upon hard acceleration. The tranny and motor mounts are good (tranny mount is poly, motor mounts = stock).
I assume this is a form of (1) wheel hop or (2) torque arm flex or (3) both.
Will an aftermarket torque arm fix this issue?
I always autocrossed my 2002 Z28 with a stock TA (on Hoosier 315/35-17's even) and had very few issues, if any. I'm not saying that you shouldn't upgrade the TA, just that many of us have been racing on the stock ones for quite some time. If you don't break it, it seems to work well in many applications. It very well could be flex. Wheel hop will flex the torque arm as a natural resonance of the wheel hop.
LS1TECH Sponsor
Do I think a TA would help? I do.
__________________
OK - thanks Sam
I have an early set of FLP LT headers and Y-pipe.
Can I go with the transmission mounted adjustible 2205 TA, and 2207 relo kit?
Thanks.
Thanks.
LS1TECH Sponsor
Shouldn't be any issue unless the Y-pipe is a lot different than the norm....
__________________
