Koni SA's and Strano Springs on a Vert
Tell me about this set up that you have. I want to get this setup but I want some more info on them before I go and get them. I have sportlines on the car now and it sucks, The car sits a good 1'-1.5' lower than it should.
Any information would be great. Or any other setups that you guys have on your verts.
Thanks.
Thanks.
you really cant compare the 2 springs. they both have completely different ride heights, different spring rates, and theeibachs are progressive where as strano's are linear. strano's are built lighter then other springs with more tensile strength to prevent wearing out and sagging. stranos are made to handle very well taking corners and be comfortable on the street. where the sportlines are more cushy, you will ride on the bumpstops, bottom out your shocks, and were made to just look good; not perform in any way shape or form
i just ordered Strano springs, Koni 4/4s, and strano front/rear bars and i know i wont be dissapointed.
ride height will not be significantly or noticeably differnt on a vert compared to a coupe or t-top, if you look up in the sticky there are muliple pics of them on cars
edit: the sticky is gone...scratch that, stickies consolidated
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
this is a camaro vert with thefront on the lower perch (since moved to the normal upper perch)
https://ls1tech.com/forums/showthrea...strano+springs
heres some pics and more links a simple search came up with
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
https://ls1tech.com/forums/showthrea...gs#post8114766
Copy & Paste Moderator
Originally Posted by SIK02SS
edit: the sticky is gone (WTF MODS!??)
LS1TECH Sponsor
More specifically stock shocks are tuned to try and damp stock spring rates. And they do that pretty poorly. So any lowering spring really should have better shocks used with them, not just ours.
__________________
LS1TECH Sponsor
Good luck, but I don't think much will come of it.
__________________
