Top of strut rusted fast, what do I do?
From: Where the Navy sends me. I'm from and call Georgia my home though.
Please help I've been at this all day anyone got any ideas how to get the d(*^ strut apart? No torch available. I have new springs and I'm on my way to get new struts. Thanks Y'all.
got friends with tools?
if not, about all you can do is soak it with WD-40 or some other penetrating lubricant for a few hours, then try working it tighter/looser, back & forth....sometimes that will help it to finally break loose. also, if you have an electric drill with a wire wheel on it, you can break loose a lot of the rust off the top so that once it starts moving, it won't lock up again as easy. maybe even a regular wire brush could work also.
LOL you guys seem to think I havent tried all the easy stuff! I need to separate the the coil from the strut to retrieve the keepers for the spring. Come on lets get creative!
no torch, no power/pneumatic tools....there's not much else really for you to do except keep working at it manually. maybe we can all do an indian dance to pray to the rust gods to release their hold on your rusted shocks.....
if nothing else, use a hacksaw to cut through the top of the rod, just below the nut.
That was note number two that I posted in the other thread. Often the bolts or nuts have to be cut. Your not saving the shock or nut so cutting the shaft is also an idea.
Just making sure you are using spring compressors too right? I'd hate to not hear from you tomorrow to find out you sent the spring through your head.
Air tools did not work for me at home bye-the-way...
The shop did this with low-tech, however. They used a BIG set of vice grips wedged into the spring and an air ratchet....
If you use any heat be careful not to damage the rubber pieces. A heat gun or hair drier rather than a torch is good.
